Date/Time: Sun, 19 Jan 2025 12:43:41 +0000
[Programming Help] - Attached Stop order for a entry Stop order.
View Count: 956
[2018-04-08 22:07:24]
User99735 - Posts: 234
Is an Attached Stop order for a entry Stop order, supported.
When I try this code
s_SCNewOrder NewOrder;
  NewOrder.OrderQuantity = Qty;// +GetOpenPositionCount(tradeNo - 1, PermData);
  NewOrder.OrderType = SCT_ORDERTYPE_STOP;
  NewOrder.TimeInForce = SCT_TIF_DAY;
NewOrder.Price1 = (double) EntryStopPrice;
NewOrder.StopAllOffset = StopLossTicks * sc.TickSize;
  NewOrder.AttachedOrderStopAllType = SCT_ORDERTYPE_STOP;
NewOrder.StopAllInternalOrderID is always returned as 0.
Regards
Vivek
[2018-04-10 13:12:59]
Dear All,
Any update on this query?
Thanks in advance.
Regards
Vivek
[2018-04-11 03:36:51]
Yes.
We are testing your code now.
[2018-04-11 04:05:16]
From documentation:
StopAllOffset cannot be used if there are no Target orders set since the Stop orders will depend on the Target orders for the order Quantity. Use Stop1Offset instead.
That really should be clear because there is no corresponding Target.
Refer to:
Automated Trading From an Advanced Custom Study: [Type: double] s_SCNewOrder::StopAllOffset
Date Time Of Last Edit: 2018-04-11 04:05:37
