Date/Time: Wed, 12 Feb 2025 12:53:29 +0000
Trading on LightSpeed
View Count: 2723
[2018-04-07 23:20:35] |
ctcamb007 - Posts: 5 |
Hello, I am moving from IB to LS and wanted to continue using Sierra Chart. Is there any way you folks can include an update to use SC with LS? Thank you. |
[2018-04-23 03:28:15] |
Can anyone answer this please? I would like to move to light speed...how difficult would it be to set up API?
[2018-04-23 06:13:02] |
No, this is not reasonable for us. It would be best for Light Speed to support the DTC Protocol: http://dtcprotocol.org/ Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-31 15:45:43] |
User86284 - Posts: 4 |
Sierra Chart Engineering: Have you considered integrating with the Lime Trading Gateway via FIX? Perhaps create a new Sierra Chart Equities Order Routing Service With Data Lime Trading Gateway https://www.lightspeed.com/automated-trading/ In 2018 the Lightspeed business combined with Lime Brokerage (owned by WEDBUSH) https://www.prweb.com/releases/2018/01/prweb15097412.htm All the best |
[2020-10-31 15:49:23] |
Oct. 31, 2018 Lime Brokerage Announces Equity Market Access Through Goldman Sachs https://markets.businessinsider.com/news/stocks/lime-brokerage-announces-equity-market-access-through-goldman-sachs-1027677434# |
[2020-10-31 15:58:17] |
Wedbush Prime Services (a full service offering for small to mid-sized money managers) offers Electronic Trading through Lime Brokerage, A Wedbush Affiliate. Perhaps a Sierra Chart - Lime (Wedbush) partnership would get SC many new clients ... Wedbush Prime Services brochure https://www.wedbush.com/wp-content/uploads/2020/02/primerservices_brochure_021120.pdf |
