Date/Time: Sun, 24 Nov 2024 06:49:50 +0000
MT4 template
View Count: 1598
[2013-10-05 11:01:49] |
jaban - Posts: 66 |
Hi Is it possible to get a MT4 template to work in Sierra thanks |
[2013-10-08 01:34:27] |
No. It requires very careful manual translation. It is not an easy task. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
