Date/Time: Sun, 19 Jan 2025 12:18:34 +0000
MA Distance from Last
View Count: 968
[2018-04-07 13:59:26] |
User371906 - Posts: 141 |
Hello, Can you please tell me if there is an indicator in SierraCharts that will give distance from a MA to last price? Thank you |
[2018-04-08 06:02:46] |
Do you mean between the moving average and the last trade price on the same chart bar?
[2018-04-08 08:48:22] |
Good morning, Yes, I am trying to identify on the main chart the highest or lowest point the market will reach measured by the middle point which for me is a 21 SMA. Thank you |
[2018-04-08 13:08:43] |
Therefore, this can be done by using the Study Subgraphs Difference study: https://www.sierrachart.com//index.php?page=doc/StudiesReference.php&ID=185&Name=Study_Subgraphs_Subtract_-_Difference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
