Date/Time: Sun, 19 Jan 2025 12:40:15 +0000
[Programming Help] - SCDateTimeMS variables as persistent variables
View Count: 788
[2018-04-07 11:51:52] |
User841591 - Posts: 42 |
I put SCDateTimeMS& LastAdjustmentDateTime = sc.GetPersistentDouble(1); in order store the time with millsecond in LastAdjustmentDateTime but I got the compiler error as below. Pls help to solve the problem. SpreadTradeSys_V2.cpp: In function 'void scsf_SpreadTradeSys(SCStudyInterfaceRef)': SpreadTradeSys_V2.cpp:173:63: error: invalid initialization of non-const reference of type 'SCDateTimeMS&' from an rvalue of type 'SCDateTimeMS' SCDateTimeMS& LastAdjustmentDateTime = sc.GetPersistentDouble(1); ^ In file included from scstructures.h:79:0, from sierrachart.h:15, from SpreadTradeSys_V2.cpp:1: scdatetime.h:1767:8: note: after user-defined conversion: SCDateTimeMS::SCDateTimeMS(double) inline SCDateTimeMS::SCDateTimeMS(double DateTime) |
[2018-04-12 01:27:30] |
Any updates?
[2018-04-12 18:45:13] |
The type SCDateTime also will hold milliseconds. This is how you need to do it: SCDateTimeMS& DateTimeMS = static_cast <SCDateTimeMS&>( sc.GetPersistentSCDateTime(1));
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-12 18:45:26
