Date/Time: Sun, 19 Jan 2025 12:44:04 +0000
Chart book color change possible?
View Count: 757
[2018-04-07 09:15:38] |
User7817001 - Posts: 96 |
I would like to change the chart book color (see attached), how? Please notice the Title bar is black, using WindowBlinds10, yet alas, the chartbook color is not :( Thank you. Mark |
Capture.JPG / V - Attached On 2018-04-07 09:14:06 UTC - Size: 86.21 KB - 341 views |
[2018-04-07 18:27:10] |
We researched if this is possible and it is. So we will implement support for a custom color for this background.
