Date/Time: Sun, 19 Jan 2025 12:21:36 +0000
All the windows in my Chartbook shrank or zoomed in upon opening from a normal close
View Count: 885
[2018-04-06 23:26:27] |
User439924 - Posts: 4 |
Hello: I closed SC as usual yesterday and opened my main chartbook upon starting SC this morning. Every chart in my chartbook was super tiny, about 4-8 times smaller than usual. All other windows on the Desktop opened as usual but not SC. Any ideas? No changes to the hardware or software were made after or prior to opening/closing SC. This is massively frustrating. The data is hard to view. |
[2018-04-07 06:26:15] |
This is just Windows 10 behavior. Windows 10 is not a stable platform. Adjust the font sizes as needed: Graphics Settings: Fonts and Text Appearance And adjust the windows as needed: Window, CB and CW Menus Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
