Date/Time: Sun, 24 Nov 2024 09:09:12 +0000
Please add "save twconfig-file" to keyboard shortcuts
View Count: 1422
[2013-10-05 06:24:09] |
tobi - Posts: 351 |
Would you please consider adding the DOM command "Save Trade Window Configuration" to the "Customize Keyboard Shortcuts".
[2013-10-07 09:07:02] |
tobi - Posts: 351 |
... or is this already available and i didn't find it?
[2013-10-08 16:10:45] |
We will see about this.
[2013-10-17 09:31:20] |
tobi - Posts: 351 |
Just updated from 1032 to 1036. Seems like you've not implemented this yet. I would assume it's not a lot of work to add this keyboard shortcut? It'd help me save quite some time in my morning routines. Thx for still considering adding this. |
[2013-10-18 03:19:02] |
Actually keyboard and menu commands are fairly involved to add. We plan to get to this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-19 05:16:50] |
This is now done.
[2013-10-19 06:09:35] |
tobi - Posts: 351 |
Thank you very much! Great help! Just downloaded prerelease 1037. Where/in which "menu" in the Customize Keyboard Shortcuts can I find it? |
[2013-10-19 06:28:14] |
Trading Keyboard Shortcuts.
[2013-10-19 08:35:25] |
tobi - Posts: 351 |
And which command? Still can't find it. Or is it not yet available in the latest prerelease? Another question: To use this command as Keyboard Shortcut, is it necessary to have "Trading Keyboard Shortcut Enabled" checked? I would prefer/recommend that not being necessary. Date Time Of Last Edit: 2013-10-19 10:02:57
[2013-10-21 08:59:31] |
tobi - Posts: 351 |
I see it's now available in the latest prerelease and "Trading Keyboard Shortcut Enabled" does not have to be checked. Thanks for adding this! |
