Date/Time: Sun, 19 Jan 2025 09:16:14 +0000
return/risk tool
View Count: 922
[2018-04-06 19:49:55] |
User606491 - Posts: 164 |
Is there a way to adjust the return risk tool (tools -> more tools -> reward/risk) so that it shows currency value ($) in addition to ticks? Ticks work fine certain markets but require an additional step of translation for others. thank you |
[2018-04-06 22:53:56] |
This tool already has this functionality. You can display the Reward/Risk values in Ticks, Points, and/or Currency Value. Refer to: Chart Drawing Tools: Reward/Risk Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-06 22:54:21
[2018-04-06 22:55:25] |
Perfect. thank you for the prompt response.
