Date/Time: Sat, 01 Feb 2025 12:43:39 +0000
Hedging on LMAX
View Count: 1191
[2018-04-06 16:10:33] |
User76183 - Posts: 69 |
Hello! Is it possible to activate hedging on LMAX? To have opened opposite positions on one instrumet? Thank you! |
[2018-04-06 17:43:14] |
No this is not supported.
[2019-07-12 15:40:35] |
Lmesd - Posts: 19 |
Hedging from 2 different accounts has some major flaws : balance split in 2, double margins locked, account transfers at LMAX are manual requests (there’s no interface to do it your own instantly, not practical to eventually equilibrate the 2 accounts). These problems add up From a single account, say that I trade with parent/bracket orders both sides. Is there a way that the resulting OCO (stop and target) orders remain active even when my position turns flat ? I would not mind to track the hedge this way, since I don’t need to rely on entry levels, neither track independant open P&Ls Date Time Of Last Edit: 2019-07-12 16:02:52
[2019-07-12 17:16:47] |
Yes you can test this in Trade Simulation Mode. Just enter both a buy and sell parent order with Attached Orders and they will both be active at the same time. We have activated your Sierra Chart account for testing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-12 17:17:23
