Date/Time: Mon, 20 Jan 2025 20:49:35 +0000
Cumulative Delta filtered for size
View Count: 2205
[2018-04-06 14:02:11]
AKR - Posts: 523
is there a way to get the cumulative delta only for volumes/per trade as eg > than 10?
[2018-04-06 17:47:02]
Yes, through Volume Filtering:
Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu)
[2018-07-09 05:58:42]
Meklon - Posts: 220
Hello Support,
I was able to successfully plot single Price On Close line for Cumulative Delta and filter it by volume, but would it be possible to combine 3 different lines of Cumulative Delta filtered by different volume criteria on the same sub-graph like on the attached example?
I suppose I must use a separate chart for each filtering size and use the Study/Price Overlay Study to plot it on the same sub-graph, but was wondering if there is a better way of accomplishing this.
Thank you.
Date Time Of Last Edit: 2018-07-09 06:20:03
imageCumulative_Delta_Filtered_By_Volume.png / V - Attached On 2018-07-09 05:58:05 UTC - Size: 67.24 KB - 662 views
[2018-07-09 06:48:26]
Yes, this is how you need to do this.
