Date/Time: Sun, 24 Nov 2024 05:28:08 +0000
Horizontal ray tool
View Count: 1493
[2013-10-05 01:48:46] |
rascal - Posts: 9 |
This is a tiny cosmetic issue but easily duplicated. After disabling the "Opaque Label Background" option in the global configuration for the horizontal ray tool, the setting reverts to enabled after restarting the platform.
Date Time Of Last Edit: 2013-10-05 01:50:24
[2013-10-05 01:49:11] |
We will check on this.
[2013-10-05 11:11:45] |
Al SC Developer - Posts: 434 |
This will be addressed in ver 1032.
