Date/Time: Sun, 19 Jan 2025 08:55:35 +0000
BidAsk Text in DOM
View Count: 757
[2018-04-06 05:04:27] |
nicktrader - Posts: 730 |
Can't find the option to change the Text Color of Bid and Ask. Both sides should be black.
[2018-04-06 17:15:59] |
I got it ==>> Trade DOM Bid (Ask) Depth Quantities
[2018-04-06 17:44:45] |
Refer to: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Trade DOM Ask Depth Quantities and Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Trade DOM Bid Depth Quantities Be sure that if you are changing this for just the one chart through Chart >> Graphics Settings, that you need to uncheck the option Use Global Graphics Settings Instead of These Settings. You can find the documentation for this here: Graphics Settings: Use Global Graphics Settings Instead of These Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
