Date/Time: Sun, 19 Jan 2025 09:19:28 +0000
RTYM18 Daily Chart
View Count: 1181
[2018-04-05 19:27:22] |
User710050 - Posts: 2 |
Hello, Why is RTYM18 Daily Chart missing yesterday and today's bars on my chart? Can you help? Thanks, Mort Username: MAFSHAR |
[2018-04-05 19:38:46] |
That is not the right symbol when you are using CQG. In File >> Find Symbol >> Futures, the symbols are listed under: F.US.RTY?## Also refer to: No Historical Chart or Blank Chart | Historical Chart Not Updating | Missing Historical Chart Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
