Date/Time: Sun, 19 Jan 2025 09:19:43 +0000
Atomatic sell or buy stop on renko bar predictor
View Count: 869
[2018-04-05 17:03:36]
User538995 - Posts: 11
I would like a very simple program for sierra to put a sell stop or a buy stop automatically according to my choice when I activate the program; 1 tick below (in the case of the sell stop) or a tick at the top ( in the cas of the buy stop) of the renko bar preditor, if the candle continues to lower or raise; the buy stop or sell stop readjusts to the new level of the renko bar predictor candle.
And of course as soon as I deactivate the program the orders are removed.
Is it possible to do this with sierra chart?
Thank’s.
[2018-04-05 19:29:33]
Yes. You need to use this particular study to control Attached Stop orders:
Attached Orders: Study Controlled Targets and Stops
We are assuming the order you want to manage is an Attached Order.
Date Time Of Last Edit: 2018-04-05 19:29:40
[2018-04-06 05:01:28]
do you know someone who could do it to me or a videot that shows me?
Thank's.
[2018-04-06 18:10:37]
There is no video. We recommend just spending time working working with the study. Here is the relevant documentation:
It probably would be best to get familiar with the Attached Orders feature first:
Attached Orders: Step-By-Step Instructions
