Date/Time: Sun, 24 Nov 2024 06:43:19 +0000
CCI Indicator
View Count: 1951
[2013-10-04 22:11:49] |
User15451 - Posts: 27 |
Dear Support, Is it possible to add the option of using a linear regression moving average in the CCI Indicator instead of a SMA in the calculation? Some other software packages make available the option of EMA,WMA etc. However i believe that being able to use a lin reg would be great. Thank you for your support Also if anyone can code this for a reasonable price i am interested... |
[2013-10-05 18:20:48] |
vegasfoster - Posts: 444 |
It's not great btw, but here you go :)
CCILinReg.cpp - Attached On 2013-10-05 18:19:58 UTC - Size: 3.02 KB - 656 views CCILinReg.dll - Attached On 2013-10-05 18:20:11 UTC - Size: 22.5 KB - 573 views |
[2013-10-05 21:37:27] |
Thank you very much - now i have to figure out how to install. Did you ever try a polynomial regression CCI too? Interesting screen name :-) |
[2013-10-05 21:51:29] |
Thank you again - i was able to load it - pretty close to what i already had. I already was running a CCI on top of a linear regression i did not know how they interacted and thought that the SMA in the CCI was a detriment. Thank you again |
[2013-10-08 03:20:27] |
We will add the contributed study to the list of User Contributed Studies in Sierra Chart for easy access.
