Date/Time: Tue, 04 Mar 2025 22:07:43 +0000
OMX Sweden
View Count: 1659
[2018-04-05 06:03:47]
User946741 - Posts: 1
Hi, Omx Sweden real-time data feed pricing is not listed under "Supported Exchanges" but the symbol is listed under the "Symbol" Page.
My question is if its possible to get real time data for OMX on Sierra and the pricing of that.
Supported Exchanges: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SupportedExchanges
Symbol: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Futures#OMX
Thank you!
/Bas
[2018-04-05 19:33:00]
No, real-time data is not available for this exchange and probably not historical Intraday data either.
Date Time Of Last Edit: 2018-04-05 19:33:14
[2018-04-05 19:53:33]
User92402 - Posts: 8
Look at Teletrader datafeed - Nasdaq OMX Nordic 39+15 total 54 euro for level 1 data.
There is also a possibility to use Interactive Broker data.
[2018-04-05 20:14:12]
Yes that is true. We did forget about the TeleTrader Data service and there is Interactive Brokers as well. Both of these are documented here:
Supported Data and Trading Services
Date Time Of Last Edit: 2018-04-05 20:14:22
[2022-01-05 11:48:07]
Bogren - Posts: 7
I'll lift this thread again.
Nasdaq OMX Nordic. Primarily the futures for omxs30 Stockholm. What is available today?
Teletrader do no longer has its feed available.
CQG has but then you should have a trading account like AMP. Probably the same for Interactive brookers?
Are there any other options?
[2022-01-07 16:57:04]
The only possibility of accessing this data would be through Interactive Brokers or possibly CQG. Refer to:
Supported Data and Trading Services: Supported Services
A trading account would be needed in both cases.
Date Time Of Last Edit: 2022-01-07 16:57:29
