Date/Time: Sun, 19 Jan 2025 09:09:18 +0000
CL calendar spreads
View Count: 1397
[2018-04-04 11:47:58] |
User357295 - Posts: 76 |
Is there a way to get CL cal spreads on SC please, I can see it on "find symbol" menu ( Futures Spreads - NYMEX ( SC Exchange Data)) but it seems not active. Please advice |
[2018-04-04 17:35:59] |
CQG exchange traded spreads are supported. Refer to: http://www.sierrachart.com/index.php?page=doc/CQGTrading.php#ExchangeTradedStrategySymbolFormat Futures Spreads - NYMEX ( SC Exchange Data) This list in the Find Symbol window is for when using the Sierra Chart Exchange Data Feed:http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#ExchangeTradedSpreads Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-04 17:36:05
