Date/Time: Sun, 19 Jan 2025 09:13:41 +0000
Sierra lags with the Timeline indicator
View Count: 1200
[2018-04-04 09:58:14] |
grantx - Posts: 244 |
I have never had a problem with Sierra until recently when I started using the timeline indicator, I do not use any indicators on my charts except for the Timeline one. The entire system becomes terribly laggy. The charts become sticky and it takes seconds to do things where they were instant before. As soon as I remove the indicator the system immediately becomes responsive again. Perhaps you guys can look into this? I find this indicator quite useful. Thank you. |
[2018-04-04 17:32:18] |
This really does not make any sense. The Time Line study will use barely any CPU time. One thing to check though but this really should not make any difference is try setting Display Custom Label Input to No: Time Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
