Date/Time: Sun, 19 Jan 2025 09:16:34 +0000
Sierra Chart data feed
View Count: 693
[2018-04-04 08:59:09] |
bounty007 - Posts: 6 |
Hello Sierra Team :-) I have two short questions. I trade CFD through Broker Interactive Brokers. I now have a question about your data feed. How exactly does it work with the transmission of the order. Is not that dangerous when I send an order to InteracticeBrokers based on your data? I mean, how do I know which data is correct? Those from your data feed or from Interactive Brokers? I mean, I'll send a blind order to Interactive Brokers. An example. The Facebook stock is displayed at $ 152.00 on your data feed at 12:00. InteractiveBrokers (TWS) will display the Facebook stock 152.20. How should I trade with wrong data in the chart? I set the limits then wrong. Or do I understand something wrong here? :-) My second question would be. Does your data feed also provide data for CFD shares from Switzerland? For example, for the shares UBS Group N, Nestle N, ABB N or Novartis N in the currency CHF? Thank you for your answers. |
[2018-04-04 17:27:19] |
Is not that dangerous when I send an order to InteracticeBrokers based on your data? I mean, how do I know which data is correct? Does your data feed also provide data for CFD shares from Switzerland? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-04 17:28:15
