Date/Time: Sun, 19 Jan 2025 12:29:49 +0000
[Programming Help] - color coded bars
View Count: 1215
[2018-04-03 23:41:35] |
User28682 - Posts: 233 |
Hi,does SC have the ability to color code a bar or mark a bar? ex: color or mark a bar on a chart if that bar closes in the top 25% of its range? Thanks! |
[2018-04-04 02:37:18] |
Yes. Refer to: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-06 04:04:03] |
Thanks, I would like to mark a bar when the previous bar closes in the lower 25% of its range(bar) AND the current bar closes in the top 25% of its range. After looking at your examples, would this formula work: (C[1]-L[1])/ABS(H[1]-L[1])< .25 AND (C-L)/ABS(H-L)> .75 so the marker or bar that gets color coded would be the second of the two bars in the test after all is true If this formula is OK, would it go in the "input" on the main graph? Thanks! |
[2018-04-06 04:23:46] |
For the proper use of the AND function, refer to: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#AND_Function Here are the instructions to enter that formula for the main price graph: Study/Chart Alerts And Scanning: To Enter an Alert Condition on the Main Chart/Price Graph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-07 00:26:36] |
So something more like this: OR(AND(C[1]-L[1])/ABS(H[1]-L[1])< .25, AND (C-L)/ABS(H-L)> .75) Thanks much! |
[2018-04-07 05:58:24] |
That does not look right. Try this: = AND(C >= (H- ((H-L) * .25) ), C[-1] <= (L[-1] + ((H[-1]-L[-1]) * .25) ) ) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-07 05:59:09
[2018-04-08 04:19:59] |
Thank you! It worked well. I then tried to produce an alert for an inside bar: current High is < previous bar high AND Low is > previous bar low using: = AND(H<H[-1],L>L[-1]) This doesn't work without getting an error message, any suggestions? Thanks! Date Time Of Last Edit: 2018-04-08 04:34:06
[2018-04-10 15:36:04] |
Does my formula look right for an inside bar? = AND(H<H[-1],L>L[-1]) Thanks again for your help! |
[2018-04-12 17:00:09] |
I'm not sure why, but I guess I may not get a response to my question above? Thanks. |
