Date/Time: Sat, 26 Apr 2025 09:39:09 +0000
CQG Routing/Data vs Sierra Chart Data - Confused
View Count: 724
[2018-04-03 17:00:32]
absorrel4 - Posts: 100
I am currently with Interactive Brokers and am thinking about changing to Deep Discount Trading or Discount Trading to save on RT commissions. That change will require me to use CQG as my routing technology (CQG FIX as recommended by Sierra Chart). However, I am confused when reading the Sierra Chart information related to CQG and after reading numerous other posts regarding CQG and the data supplied. In the "What is Included" section for CQG, SC says that streaming real time data is included. However, I have read other posts that say CQG is just the routing technology and that the data feed for the SC Charting software should come from an additional separate SC data package (for an additional $35 per month plus exchange fees). Can you clarify? Thank you...
[2018-04-03 19:04:28]
We recommend just using the market data from CQG unless you have a problem with it.
CQG does provide real-time market data.
