Date/Time: Sun, 24 Nov 2024 06:14:11 +0000
[User Discussion] - Flatten or Cancel Spreadsheet trading
View Count: 1516
[2013-10-04 18:20:43] |
toews&kane - Posts: 209 |
Hi there, I am using this code in J29 it doesn't seem to be working. I just want it to flatten at 16:09:00 It's returning true right now. Suggestions? =AND(OR(J41-INT(J41)<TIMEVALUE("16:00:00"),J41-INT(J41)>TIMEVALUE("16:30:00"))) |
[2013-10-04 18:27:52] |
Do you see a message in the Trade >> Trade Service Log indicating a Flatten and Cancel operation for the symbol at the time it became TRUE?
[2013-10-04 19:03:07] |
Sawtooth - Posts: 4118 |
Try this instead: =J41-INT(J41)>=TIMEVALUE("16:09:00") |
[2013-10-04 21:21:13] |
but I also want it to return false at 17:00 so that it enters into a trade again on a new day
[2013-10-04 21:59:41] |
Then try this: =AND(J41-INT(J41)>=TIMEVALUE("16:09:00"),J41-INT(J41)<TIMEVALUE("17:00:00")) |
