Date/Time: Sun, 19 Jan 2025 09:00:17 +0000
Disable/Enable one side of automated trading
View Count: 620
[2018-04-03 15:53:17] |
User835963 - Posts: 18 |
Hello support, is there a way to disable/enable auto trading for one side of the market? I mean if I have a spreadsheet for trading, trading based on alert condition or ASCIL running and I'm coming to an area of interest, lets say the high of the day and just in case my condition for long return true momentarily resulting in unintentional long entry. is there a way to add a button to trading menu of trading window or the spreadsheet to disable one side of trading rather than disabling both sides? you Guys have the feature of disabling auto trading all together which is fantastic and I have a button set up in one of the control bars to quickly turn auto trading on and of. if it is not too much or you have a better idea to achieve the same thing I would appreciate it, otherwise what we have right now will suffice. thank you for all your hard work regards, Heather |
[2018-04-03 19:05:53] |
is there a way to disable/enable auto trading for one side of the market? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
