Date/Time: Sun, 19 Jan 2025 09:03:32 +0000
Bitmex Market Depth
View Count: 682
[2018-04-03 08:49:52] |
User789204 - Posts: 15 |
Market depth now about 20-30, and it is impossible to change it Make it 200 at least or custom settting. I'm using non-Trading Direct connection. Thanks |
[2018-04-03 08:54:27] |
For what symbol? We see 50 levels for XPTUSD-BMEX.
[2018-04-03 09:37:10] |
XBTUSD-BMEX
[2018-04-03 09:53:04] |
Add please more on XBT, Last days volatility is very high and move for +200 -200 occurs very often.
