Date/Time: Sun, 19 Jan 2025 09:04:11 +0000
TF changing problem
View Count: 1052
[2018-04-03 07:44:26] |
User787215 - Posts: 14 |
Hello i have a problem which is, when i add a symbol already used in my Chartbook i cannot change the time frame for the symbol choosen, it said to me "You have performed an operation which cannot be completed because this chart is being refrenced by studies in other charts in the Chartbook. Do you want to clear those references ?" Whatever if i click yes or no the tf will always go back to the previous one, loaded orginaly. What should i do ? Thanks for support |
[2018-04-03 18:07:31] |
This is explained here: Unable to Change the Bar Time Period for Charts You need to find out what chart is referencing that chart you are trying to change the bar period for and remove that reference. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
