Date/Time: Sun, 19 Jan 2025 09:04:15 +0000
Help with transferring chartbook + Spreadsheet
View Count: 1529
[2018-04-03 05:12:55] |
User651753 - Posts: 77 |
I am trying to backup and transfer my Chartbook 1.to my VPS ( i don't want to copy the whole Sierra chart folder) 2.I want to transfer my chartbook here to get help with it 3. Backup on dropbox and SSD I don't think I am saving it correctly ... when I copy the CHT file, it copies all the indicator and set up and build the spreadsheet (even with correct name), however, all the spreadsheet calculations are all empty I tried to add the SCSS ( it look a bit small only 18KB) What am I missing? |
111MA Spread.Cht - Attached On 2018-04-03 05:11:36 UTC - Size: 48.83 KB - 334 views Attachment Deleted. |
[2018-04-03 19:38:23] |
Use the file sharing feature and send both the Chartbook and spreadsheet file to your own Sierra Chart account name: File Sharing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-03 19:38:48
[2018-04-04 02:32:08] |
what about when i want to share the idea here? is there a different way to save my current setup as a complete file? what about backup ( without backing up the whole Sierra folder) |
[2018-04-04 05:45:38] |
For instructions to attach a Chartbook here, refer to: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile is there a different way to save my current setup as a complete file? For backups of Chartbook files, refer to: Chartbooks (Workspaces): Accessing a Backup Chartbook File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-04 10:40:29] |
ok i must be missing how to save the chartbook with correct spreadsheet , you can see with the chartbook i added that it doesnt save every thing for me
[2018-04-04 17:39:08] |
You can save the files with File >> Save All.
[2018-04-05 11:14:36] |
you may not understand what I'm saying? , did you open the cht file I attached? when i save all , then copy and paste the cht file to another computer or share it on the fourm , it doesnt save all the spreadsheet calculation .
[2018-04-05 18:05:45] |
The spreadsheet is another separate file containing the spreadsheet data and ends with .SCSS. That file needs to be transferred as well.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-05 18:06:12
