Date/Time: Sun, 24 Nov 2024 05:26:07 +0000
linking charts together with the crosshair
View Count: 2653
[2013-10-04 15:42:15] |
User77503 - Posts: 48 |
how can i link a few charts together so that if i am using the crosshairs on one chart it will move the crosshairs on the other charts at the same time according to the time of day?
[2013-10-05 01:40:49] |
This is possible and is documented here: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ChartValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-05 18:25:17] |
i have 8 charts open but i only want to have the crosshairs move simultaneously on 3 of them, is that possible?
[2013-10-05 20:16:19] |
No. Would have to be all eight of them. Unless only 3 of them are within the same Chartbook.
