Date/Time: Mon, 20 Jan 2025 14:00:19 +0000
[User Discussion] - chart values/crosshairs
View Count: 2696
[2018-04-02 20:53:59]
User635423 - Posts: 51
I have my chart values/crosshairs box checked so that I get the data popup when I click on the candle. Is there a way to configure the data in the popup to show the total range of that candle from high to low so that I don't have to calculate it?
Thank you
[2018-06-26 16:11:13]
User791263 - Posts: 151
I have a similar problem. My crosshairs worked fine for years. I have NOT updated versions.
All of a sudden, the values does not read any but the last bar, and on non-price charts, it used to give the value of the Sub-indicator wherever it was place; now it does nothing.
On horizontal lines, it would give value as moved, now it always gives degrees.
I tried the configure settings. .no luck.
I activated the compact tools value window, and that works but it is not compact; It shows all the regions.
For now I have reduced it, but that is way more data than the standard black window that now shows only Region 1 end of bar values.
Date Time Of Last Edit: 2018-06-26 16:21:40
[2018-06-27 12:13:49]
You really need to read this documentation over carefully to understand this functionality and how to use it and configure it:
Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools
Also for the record most everything you are saying is not really making any sense. For example, if you only see the degrees when using a Drawing Tool, then you just have to scroll to the top of the window.
Date Time Of Last Edit: 2018-06-27 12:16:27
