Date/Time: Sun, 19 Jan 2025 09:16:47 +0000
Displaced moving averages
View Count: 1479
[2018-04-02 15:35:15] |
William F - Posts: 6 |
Is it possible to utilize a Displaced Moving Average? I dont see that in the Studies Window. Thanks
Date Time Of Last Edit: 2018-04-02 17:53:34
[2018-04-02 17:53:27] |
Yes. You need to use the Study Subgraph Displacement setting: Chart Studies: Subgraphs Tab >> Displacement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-02 17:53:44
