Date/Time: Sun, 24 Nov 2024 05:20:36 +0000
[User Discussion] - something like ATR study
View Count: 1500
[2013-10-04 13:07:42]
mayerrs - Posts: 70
hi, i would like to ask if i am able to make something like this:
i would know how many times is last bar bigger then an avarage prior of last 5 or 10 or whatever bars. i tried use to ATR but it is not what exactly i mean.
can somebody help me how to do it?
[2013-10-04 14:06:29]
namlem - Posts: 94
Hi, I don't know if there is a study for this, but you can do it in a spreadsheet (if I understood correctly)
this is relation of last bar to average size (from High to Low) of last 10 bars:
=1/((AVERAGE(C4:C14)-AVERAGE(D4:D14))/(C3-D3))
in result: 0.5 means current candle size twice smaller than avg(10), 1-equals, 2 - twice bigger and so on..
[2013-10-04 14:21:36]
mayerrs - Posts: 70
thanks for your respond but i meant something without spredsheet because i have too many chartbooks and charts so i was wondering i would see the number somewhere on chart header row.
i would see for example "2.5" and i would know the last bar is 2.5 times bigger than last 5 or 10 bars..
is this possible?
[2013-10-04 14:29:49]
namlem - Posts: 94
Probably you know, that with "Text Display from Study" you can output any value from the spreadsheet to a chart...
If to achieve the same without spreadsheet is possible i don't know. sorry.
