Date/Time: Sun, 19 Jan 2025 09:05:01 +0000
DOM setting
View Count: 733
[2018-04-02 13:13:43] |
User583898 - Posts: 7 |
I,m not able to set my DOM properly. I would not get any datas into the ask and bid column.
[2018-04-02 18:06:35] |
The cash Forex symbols do not provide any market depth data unless you are using LMAX: LMAX Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
