Date/Time: Sun, 24 Nov 2024 06:56:13 +0000
Volume profile lines
View Count: 1532
[2013-10-04 12:49:06] |
pismo10 - Posts: 159 |
When I draw a Volume profile I have the value area highlighted and I have lines extending to the "End of Window" Works great. The problem I have is if the price area that created the volume profile is off the screen the extended lines disappear. If I scroll back a little they pop up again. Any way to keep them visible all the time? Thanks |
[2013-10-05 02:56:50] |
We have to consider this.
[2013-10-08 01:37:00] |
One thing that you can do is extend the lines Until Future Intersection. This will keep them extended until they intersect future prices. This is the only reasonable way to accomplish what you want .
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-08 01:37:27
