Date/Time: Sun, 19 Jan 2025 09:03:48 +0000
Number Bars Calculaed values weekly range not true i.e. is the monthly range
View Count: 713
[2018-03-30 16:23:45]
User657944 - Posts: 173
Hi Team as per istruction manual the weekly Range is "Weekly Range: This is the High to Low price range as of the chart column it is displayed at, since the beginning of the week. A week is considered to begin on Sunday".
Well I have the calculation on FGBL german Bund on Eurex that is correct for the daily range but the weekly is indicating the Monthly range. In fact the montly range is 3.48 points with min at 156.22 and max at 159.70
Since there's no any possibility to set the weekly range could you please look and tell me if I'm wrong or please look into the indicator and modify the way is doing the calculation.
thx.
Attached the screeshot with number bars display.
imageweekly range.png / V - Attached On 2018-03-30 16:22:14 UTC - Size: 18.29 KB - 284 views
[2018-03-30 20:46:21]
John - SC Support - Posts: 37327
We found a problem with the weekly stats not being properly reset if there was no data actually on a Sunday. We have fixed this and it will be in the next release.
[2018-03-31 15:05:37]
thx John well done
