Date/Time: Sun, 19 Jan 2025 09:03:24 +0000
Trade DOM Study Values to Labels
View Count: 1352
[2018-03-30 15:06:02] |
Mike_B - Posts: 16 |
I am trying to turn my Trade DOM label that is adjusted manually so that it is automatically calculated. For instance, in the attached screenshot you will see the text "VWAP" which the value is adjusted manually and also a blue dashed line which is also the VWAP but is a study overlay from another chart that is calculated automatically. I have tried to turn the dashed-line study overlay into a text label but when I click the "apply" button, SC changes it back to a dashed line. I have searched all over the support forum and the user manual but could not find anything about this. I am not sure if this is even possible at the moment or if anyone has ever asked for this but it would be extremely helpful for certain study values derived from other studies can be automatically displayed. Currently, I am having to manually adjust the label value every 30 minutes and for other instruments I am having to adjust these values every 5-10 minutes which is less than optimal. I would like to request this feature if it is not yet available or if it is I would appreciate any guidance. Thanks in advance for your help. http://www.sierrachart.com/image.php?Image=1522421309638.png |
[2018-03-30 21:36:04] |
ticinotrader - Posts: 397 |
On the source chart, change the overlaid VWAP study's Name Label -> Horizontal Align settings to 'Label Column' (Study Settings -> Subgraphs). Then if you have a Label Column turned on on the DOM, the VWAP Name Label will be displayed there automatically. Nice DOM btw ;-) |
[2018-03-31 04:54:03] |
You need to set this Study Input to No: Study/Price Overlay Study: Use Styles and Widths from Source Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-31 04:54:11
