Date/Time: Sun, 19 Jan 2025 08:57:56 +0000
[User Discussion] - continuous contracts on Bitmex
View Count: 1505
[2018-03-30 13:27:43] |
Ulaju - Posts: 56 |
Hi. Expiration date for futures contracts was today for alts in Bitmex, and now I can see only one day in the new charts. I'm trying to use the "continuous Contract" feature but it doesn't seem to work for me. Is there any special way to make this work on Bitmex? Thanks a lot |
[2018-03-30 22:40:53] |
The proper solution to this is to use the non-expiring symbols like: XBTUSD-BMEX. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-31 06:42:29] |
Ulaju - Posts: 56 |
Yes, XBTUSD-BMEX works fine for me, but I was talking about the alts. Let's take for example ADA: The symbol ADAM18-BMEX has accurate price, volume works fine, but it only has two days of history (actual contract). The symbol .ADAXBT-BMEX has longer history, but the price is not accurate and the volume doesn't work The symbol ADAXBT-BMEX does not exist and it gives an error So... what symbol am I supposed to use? |
[2018-03-31 17:44:36] |
We have absolutely no idea. This is not within the scope of our support whatsoever.
