Date/Time: Sun, 24 Nov 2024 06:01:16 +0000
Value of lines produced in tools showing up in values scale
View Count: 1367
[2013-10-04 01:46:38] |
DECRASH - Posts: 10 |
I asked this earlier but did not see a response. Let's say I do a Raff regression channel in the tools area. The lines are plotted on the chart, but I cannot figure out how to show the values of these lines either on the lines themselves or in the values scale area. How is this done?
[2013-10-04 02:08:12] |
This is not supported.
[2013-10-04 02:57:50] |
M5amhan - Posts: 468 |
would be a great feature though
