Date/Time: Sun, 19 Jan 2025 08:59:53 +0000
Spreadsheet - Draw tools
View Count: 1578
[2018-03-29 18:17:02] |
User747654 - Posts: 39 |
I would like to use the spreadsheet to be able to plot an extending rectangle. Each morning I manually plot my support and resistance levels using the Extending Rectangles tool. I would like to be able to type the levels in and have them plotted that way. Is this possible? Thank you. |
[2018-03-29 19:40:07] |
Instead what you can do is use 2 subgraphs with the Spreadsheet Study to create a filled area using these Draw Styles: Chart Studies: Fill Rectangle Top (ACSIL: DRAWSTYLE_FILL_RECTANGLE_TOP) and Fill Rectangle Bottom (ACSIL: DRAWSTYLE_FILL_RECTANGLE_BOTTOM) Or you could use the Horizontal Lines study: Horizontal Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-29 19:43:12
