Date/Time: Sun, 19 Jan 2025 06:34:45 +0000
1725 ? on dom
View Count: 791
[2018-03-29 13:54:22] |
User20450 - Posts: 330 |
i didnt change anything and now these are overlapping on new update , thank u
2018-03-29_09h52_49.png / V - Attached On 2018-03-29 13:54:16 UTC - Size: 32.53 KB - 290 views |
[2018-03-29 18:41:52] |
We are looking into this. Most likely an issue on the CQG side. But we will figure out a solution. When you see this just reconnect: File Menu: Procedure to Reconnect to the Data and Trade Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-29 18:42:46
