Date/Time: Sun, 19 Jan 2025 09:07:04 +0000
can't get spaces in front of SCSubgraph's short name
View Count: 809
[2018-03-29 09:54:52] |
MD236 - Posts: 28 |
Hi, I'm not able to place space charaters into the subgraphs shortname to get a little space between a indicator line and the name My code looks like this SCSubgraphRef ibhigh = sc.Subgraph[0];
It looks like the space characters are deleted after compiling.ibhigh.Name="IB-High"; ibhigh.ShortName=" IB-High"; If I do the same within the chart study configuration it works, how can I achive this in programming? Thanks Mario |
[2018-03-29 18:27:18] |
Not sure why this is a problem. Those spaces are not being trimmed from what we can tell.
[2018-04-02 14:37:08] |
MD236 - Posts: 28 |
Hi, sorry, but the problem was on my side, I used the wrong cpp-file Thanks Mario |
