Date/Time: Sun, 19 Jan 2025 09:09:20 +0000
Market Replay
View Count: 765
[2018-03-29 09:02:59] |
User367844 - Posts: 3 |
Hi Support, I have just downloaded a trial account and would like to ask the following question: I'm running on volume based CL contract. Just to confirm, if i will to subscribe a 10 years historical data from CQG and use it on Sierra Chart (Market) replay, is there any auto rollover of contract for it? Meaning i just use the "start date time" and input past date (example 01-Jan-2008) and i would be able to run the replay chart from then to the present date? Kindly advice. Thanks. Date Time Of Last Edit: 2018-03-29 09:07:21
[2018-03-29 19:46:34] |
For data you will only want to use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service That is the very best choice and no other. You cannot access 10 years of data from CQG. There is no support for that. is there any auto rollover of contract for it? Yes. You need to use this functionality:Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-29 19:57:13] |
You also need to set the chart to be a Continuous Futures contract. Refer to the documentation here: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
