Date/Time: Sun, 24 Nov 2024 06:33:23 +0000
Problem with two accounts
View Count: 1287
[2013-10-03 17:22:55] |
almani123 - Posts: 4 |
I have created two accounts for Windows 7 , because I need the setting parameters of the software to be different for each account . each account has two different profiles and they need to login and work on the same computer (but not at the same time) . The two accounts have to be able to create personal settings without one profile accessing the other profile (chartbooks). unfortunatlty the software permits the personal setting to be accessed . How can we resolve this problem ?? |
[2013-10-03 17:25:27] |
The way to accomplish what you want is to install 2 separate copies of Sierra Chart on the computer. Here are the instructions for this: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html These copies of Sierra Chart can be used at the same time or separately. Either way is fine. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
