Date/Time: Sun, 19 Jan 2025 06:15:23 +0000
Fixed (non moving) vertical line in DOM possible?
View Count: 1051
[2018-03-28 16:32:28]
User7817001 - Posts: 96
Please see attached
Is it possible to add a fixed vertical line in the center (top/bottom) of the DOM ladder?
imageCapture.JPG / V - Attached On 2018-03-28 16:32:06 UTC - Size: 69.31 KB - 357 views
[2018-03-28 18:55:03]
Do you mean a horizontal line.
If so, refer to:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Trade DOM Recenter Line
[2018-03-28 18:55:47]
Additionally, on the Trade DOM select Chart >> Studies and add the Line study with an appropriate value. Be sure to set the Chart Region to 1 for the study. This will not draw the line through the DOM columns.
Documentation for the Line Study can be found here:
Line
Also refer to the prior post.
Date Time Of Last Edit: 2018-03-28 18:56:12
[2018-03-28 20:17:44]
Perfecto! Gratzi!
The line WAS horizontal (glad I provided the picture)
1st recommendation was spot on, thanks.
You and the support team is fantastic!!!!
Mark
