Date/Time: Sun, 19 Jan 2025 06:27:47 +0000
User Question
View Count: 634
[2018-03-28 05:12:38]
Sierra Chart - Max - Posts: 5779
I think I ma paying the cme twice. Once at GAIN every month and once with Sierra. Is this the only way that it works?
If i open to instances of Sierra chart do I need to subscribe to 2 monthly data charges with the CME and with sierra chart? BAR CHART?
thank you
Sierra Chart Support
[2018-03-29 04:39:36]
If you are using the Sierra Chart Exchange Data Feed, then you do have to pay for the exchange fees through the Sierra Chart Exchange Data Feed. See if you can cancel them through gain capital.
No, if you use File >> New Instance:
Using DTC Server for Data and Trading in Another Sierra Chart Instance
