Date/Time: Sun, 19 Jan 2025 06:39:01 +0000
Automated Trading Strategy
View Count: 1936
[2018-03-27 18:20:53] |
User857867 - Posts: 5 |
May I know if you offer Automated Trading Strategy ? If yes, what programming language will it be coded in ?
[2018-03-27 19:48:08] |
JoseyWales - Posts: 67 |
Sierra Chart has a library of variables and functions implemented in C++ for which you can program your own custom indicators as well as strategies. Examples of indicators and trading systems used in Sierra Chart can be found in the folder ACS_Source, where your Sierra Chart was installed. See these links in the documentation to learn more: Table of Contents | (Advanced Custom Study/System Interface and Language (ACSIL)) |
[2018-03-28 07:15:34] |
There are several ways this can be done and this is explained here in the introduction: https://www.sierrachart.com/index.php?page=doc/AutoTradeManagment.php#Intro Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
