Date/Time: Sun, 24 Nov 2024 06:21:47 +0000
User Email Questions - Volume Alert
View Count: 1345
[2013-10-03 15:21:49] |
Sierra Chart - Max - Posts: 5730 |
Ive looked on sierra chart what I need to do and I cant find it. What I need is a sound alert to go off when numbers bars gets above a 1000 contracts (volume). I use 4 minute numbers bars and every time the volume goes above 1000 I need a sound alert. So can I get that on sierra chart? Please refer to the documentation here on how to add an alert to your chart: http://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html#EnterAlertOnMainPriceGraph You will want to use the following formula: =V>1000 Sierra Chart Support |
[2013-10-03 23:50:28] |
Post verified.
