Date/Time: Sun, 19 Jan 2025 12:29:51 +0000
ACSIL / DRAWSTYLE_TEXT different behavior on Study Summary and Chart
View Count: 948
[2018-03-27 12:09:00]
wwwingman - Posts: 185
Hi
I use the Study Summary and one of my study subgraph style is DRAWSTYLE_TEXT.
This subgraph property DRAW_ZEROS is set false and the text is drawn properly on the chart when some conditions are met.
But, in the study summary, the text is always drawn, even when the value of the subgraph is 0.
I expected to have the same behavior on the chart and in the study summary (text appear in the study summary when conditions are met / drawn on the chart..)
Am I wrong ?
-- W.
[2018-03-27 19:33:11]
Marek F - Posts: 244
SC, i use this feature to display any text in the Study Summary Window without drawing it on the chart, so if you will change it, please fulfil this my request: Display text in the Study Summary Window
Thank you
[2018-03-29 09:42:16]
Hi Sierra engineers, is it possible to have an answer to my above request ?
Am I wrong ?
Thank - you.
[2018-03-29 18:24:16]
This is all pending review. This needs to be reviewed and we need to update the documentation and see what we can do to accommodate the requests.
We should be able to accommodate what everyone requires. Just allow us about a week.
Date Time Of Last Edit: 2018-03-29 18:24:40
[2018-04-09 23:57:55]
OK we have reviewed this. Definitively, Subgraph Draw Zeros has no relevancy in the case of the Study Summary.
We have done some enhancements and have documented the current functionality as it is in the latest revision of 1730 and higher. Refer to:
Study Summary Window: Number, Text, and Color Control for Study Summary Subgraph Cells
You should be able to accomplish what you want.
Date Time Of Last Edit: 2018-04-09 23:58:47
