Date/Time: Sun, 19 Jan 2025 06:11:29 +0000
QuoteBoard
View Count: 1385
[2018-03-26 14:54:02] |
User990040 - Posts: 6 |
At 10:20 AM EDT, my Quoteboard was showing the ESM8 down 1.25 and the NQM8 down 14. My daily chart shows the ESM8 and the NQM8 up substantially, just like news sources are reporting. The ESM8 was up 40 and the NQM8 was up 115. What is the reference point for the open and close on the QuoteBoard and is it adjustable. Clearly mine is off. Thank you.
[2018-03-26 15:55:21] |
Refer to: Getting Quotes: Field Descriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
