Date/Time: Sun, 24 Nov 2024 06:31:43 +0000
User Email Question
View Count: 1943
[2013-10-02 23:15:53]
Sierra Chart - Max - Posts: 5730
Hej
For 2 days ago wrong chard not right drawing. About half an hour after the opening of trade in GBL, there are endless candles / bars. Records.
In addition, another problem, which also does not work:
I had programmed me in a exelshed a special funtion for the turning points of a Moving Average Hull. As of today, it no longer works. If MovEv example stands above the AS column, then the formula is = (AND (AS3> AS4, AS <AS5), 1, 0). This was wrote in column K, on in line K3: entered. In column M on line M3 ditto, only > and <switch.
As a result, I received exactly at the turning point downward or upward arrow down and vice versa.
Question: How can I make this function, so make the turning point again Duch an arrow clearly visible?
How / where I could program it? You might have an example of the chard I can copy it?
Best Regards
Sierra Chart Support
[2013-10-03 17:42:39]
1. For the first problem, go to the chart and re-download the data by selecting Edit >>Delete All Data and Download.
If you still need help, we need to see an image of the chart. Provide it by following these steps:
https://www.sierrachart.com/index.php?l=PostingInformation.php#Image
Please respond on this page. You will need to login if you are not already by selecting Help >> Support Board from within Sierra Chart. After logging in, come back to this page.
2. We do not provide Spreadsheet formula writing help.
Date Time Of Last Edit: 2013-10-03 17:42:53
[2013-10-04 15:19:30]
From user:
Hej
Ok I understand "We do not provide Spreadsheet formula writing help", but this function that I use it once was, so they allow me to my question: By what this new function has been replaced, where you can program something similar.
Manny Thanks
The existing function "MACD crossover system" which already comes pretty close to what I am looking for, only should this not based on sluggish MACD, but better at faster on Moving Average-Hull. Who could help me with programming support me. This would be a powerful feature that would be very interesting to other future-traders.
[2013-10-08 03:45:10]
Please see:
http://www.sierrachart.com/index.php?l=doc/SierraChartStudyAndSystemProgrammers.html
