Date/Time: Sun, 19 Jan 2025 06:24:54 +0000
line chart - color bar/hollow
View Count: 727
[2018-03-26 12:46:17] |
cross - Posts: 70 |
Hi, Using Color Bar Based on Alert Condition study with Color Bar or Hollow settings and then switching to line chart (LOC, eg. temporarily) renders the result a bit messy. It seems that a Line is used to color the LOC but it would be better using the Line - Skip zeros implementation, if possible under the hood. Thank you |
line chart coloring.PNG / V - Attached On 2018-03-26 12:43:32 UTC - Size: 4.05 KB - 246 views |
